sunroof is leaking into my interior lights between the visors
2001 Subaru Outback the sunroof is causing water to run into my interior lights between my visors
Es esta una buena pregunta?
Hi,
It may be that one or both of the front drains on the sunroof is blocked or has become detached from the sunroof.
Here is a link - go to post #27 which shows where one front drain outlet appears in a 00-04 Outback. There should be another one in a similar spot behind the front wheel on the other side.
Fue útil esta respuesta?
Be sure to check the sealing inside of the sunroof, for my car the sealing is solid, so no leakage should occur.
Thanks,
-John
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,591
