Saltar al contenido principal
LCD screen: iMac 20" 20 and Isight
Did a research on google and cannot find an answer.
Is it possible to put an apple Imac screen from an Imac G5 20" into an G5 20"Isight version?
Es esta una buena pregunta?
Puntuación -1
1 comentario
why don't you try to ask any it support team? They are the expert in any it support related queries.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The numbers in parenthesis that follow the model number must match exactly. If you need LM201W01(ST)(B2), you must replace it with LM201W01(ST)(B2).
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
+ Agreed - It's the revision numbers ((A1), (B1)) that matters. Sometimes with the wrong revision screen those iMacs won't even boot up.
- de
"NO that's not an exact match. I don't think you're ready for DIY repairs."
Actually it was a question for Imac LCD...Someone has already done it but its in french.
Thanks for your input
- de
??? Imac LCD...Someone has already done it but its in french. ???
- de
Respuesta Más Útil
If the part
numbers on the back of the display are the same yes, if not no.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Puntuación 2
2 comentarios:
So it the Isight is LM201W01(ST)(B2)and the imac g5 is LM201W0(SL)(A3), would it fit?
thanks
- de
- de
It does not always have to be an exact match. For example, I have replaced a (SL)(A1) with both a (SL)(A2) and (B5). Both worked. Some other suffixes will not work though. You have to check the data sheets to see what the voltage level is and what type of video signal is sent from the video card to the LCD are.
Puntuación 1
1 comentario:
not a bad answer to a very old question ;-)
- de
Añadir tu respuesta
lunchbx2 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,436
