Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2688 Ver todo
iPhone 6S home button and touch ID not working after screen replacemen
Hi, I've been repairing phones for a while. I repaired an iPhone 6S screen and attached the original home button to the new screen. However the first time I plugged it all in the home button worked but not the touch ID. I then unplugged everything to get the touch ID working, re- plugged the home button cables and now neither the home button nor the touch ID is working. Ive plugged everything in multiple times since. No difference. Any ideas? Also- the home button does seem to press down quite far however the screws are in as tight as they will possibly go and I'm not sure that that would affect anything? Any ideas? Thanks! :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I would try a new screen for starters. sometimes the ribbon cable behind the plate is bad in the aftermarket screens
Fue útil esta respuesta?
Puntuación 1
I would recommend trying a different screen on the device, it might be a bad home button cable on the screen.
If it doesn't work on a different screen then check the button flex for any damage, if it is damaged then you will need to replace the button but you will lose Touch ID permanently
Puntuación 1
Añadir tu respuesta
Cara estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 967
