Saltar al contenido principal
Where to find a battery replacement?
Hey guys... I'm looking for a battery replacement for my Philips GoGear Vibe Mp3 player.
Here's how it looks like: https://drive.google.com/open?id=0BxnOK5...
So I'm basically need a compatible battery that would fit this small space of about 2.4mm width, 3.5mm height and 4mm thick.
I've been looking all over the place and found some similar batteries in China but the shipping costs more than a new Mp3 player.
I'm from Romania so if you know any place where I could get such a battery from Europe or somewhere close I would be really grateful!
Thanks in advance,
Cristian
Es esta una buena pregunta?
Puntuación 3
3 comentarios
i have the same problem too
but i already had a battery laying around with 200 mAh will this work or will this also get puffed
- de
If the dimensions fit, you can try it out and see what happens.
- de
Hi please the battery work good or no ?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I have finally found a compatible battery on ebay.
Here's the link if anyone else is interested: http://www.ebay.com/itm/111850527802?_tr...
I've ordered the new battery and waiting for the shipment to arrive. Will update this thread once I get it.
UPDATE: the battery has arrived and it fits perfectly... check out the picture bellow! And since it has a higher capacity than the original one, it lasts even longer before I need to charge it again. By the way the charging works normally without having to solder the blue wire to the black one. So I'm very happy that I've ordered this battery.
Fue útil esta respuesta?
Puntuación 3
13 comentarios:
Hi @dpcdpc11 ,
Hopefully it will fit.
The size shown on the battery in the picture you posted is 3.8mm x 24mm x 36mm.
So while the new one is smaller in length it is slightly thicker and wider. (4.0mm x 25mm x 35mm)
I realize that it is only 0.2mm thicker and 1.0mm wider but as I said I really do hope that it does fit properly for you and that it is not just that fraction to deep to allow the unit to close properly or that you have to put to much pressure on the battery either to close the case.
Good luck!
- de
Hey Jay... in theory there's enough space to fit the new battery but since these are not 100% perfectly sized products it might not fit... considering the small price of the battery it's not a big risk.
One question about the thickness... would it be a problem is the back case of the mp3 player puts too much pressure on the battery?
- de
Hi @dpcdpc11 ,
Given that it is hopefully only 0.2mm I don't think that it will.
My main concern was that this might just be enough to stop the case from closing properly and that (and I am probably wrong about this) it will cause the case to bulge over the battery and not latch onto the sides correctly. I say this because I think that the battery will be stronger than the case and will not compress any more (unless you put a whole lot of pressure on it - which I hope that you don't have to).
I only made my first comment because in some devices they have no margins at all to play with and I just wanted you to be aware of this if you had a problem closing the case and were wondering why it didn't close properly.
Again fingers crossed that it will fit in with no problem.
- de
Another problem might be that the new battery has only 2 wires where as the original one has 3.
After doing some research I see that the best fix is to connect the extra wire (the blue one in the case) to the black wire.
What's your take on this, Jay?
- de
Hi,
There is a risk because the "thermal sensor" wire is there to protect the battery from overheating (and also to protect you as well) and there being possibly disastrous consequences when being charged. If the battery goes 'critical' the reaction cannot be stopped.
You could try your way and see how hot the battery gets when being charged to 100% (if it doesn't start to charge try placing a 10k Ohm resistor between the blue wire and the black instead of a direct connection)
If you really don't want to take any chances there is always this option when charging the battery.
Just remember if you do charge it to take note of the time it takes to fully charge and then on subsequent charges set a timer or something to remind you to check it rather than allowing it to continue charging 'unsupervised'
- de
Mostrar 8 comentarios más
NOT solved!
I tried this; recharging will not work for long. If you leave it plugged in for too long (a mere matter of hours...), it will fry the leads.
Philips should have continued to sell replacement batteries; but they're a bunch of jerks. If their sales aren't in the zillions, they always discontinue their products. Even if you buy this product unopened, it will by now not be working; the lithium battery will be shot and this replacement technique will not work.
For the best alternative, buy a Sony MP3 player new (at the time of this post, for a similar device I would recommend https://electronics.sony.com/audio/walkm...); not an aluminum case, but a hard plastic one. Not quite as rugged as the Philips, but good enough.
[NEVER buy a Sansa! I bought two and they went south in a matter of a couple of months. They now have a supposedly rugged one -I wouldn't trust it at all after that experience...]
For those who wonder why one would be interested in such a device in this era of smartphones: for security reasons, I use a dumbphone. I have no trust whatsoever of Andoid/Google or iPhone/Apple. A small device such as this lets me retain an ability to listen to songs on the go; the Sony model I cited has no Wifi -a vector for hacking. Most dumbphones have no decent mp3 player capability...
Puntuación 0
Añadir tu respuesta
Cristian Dragos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 37
Ultimos 30 días: 159
Todo El Tiempo: 14,648
