My speedometer stopped working after the radio was stollen
how to fix speedometer after stereo was stollen
Es esta una buena pregunta?
Matthew Budau , Check all your fuses if all test good, you will have to look under dash and examine all the wires/plugs to see what all got cut, loosened or damaged and make necessary repairs. I hope the links below may also help, wire color codes and schematics. It could also be a problem with stepper motor behind the cluster which may have failed, last link below. Good luck.
http://www.jalopyjournal.com/forum/threa...
http://www.autozone.com/repairguides/Ava...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 149
