Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 3299 Ver todo
Pregunta Cerrada
I dropped my iPhone and now I cant hear anything during calls
well as it says in the subject , during calls i cant hear anything or cracking sound and sometimes its fine :S
what should i do?? do i have to replace anything or there is a simple fix??
and can u plz provide pics and tut how to fix it ?
thx alot
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
plzzzz help
i even went to a repair shop and didnt know how to fix it :(
- de
hello
the repair shop found out its a broken "IC sound",
the problem is that the repair shop doesnt have one,
where is this IC , is it in the logic board ?
and where can i get it ?
- de
one more question, my iphone is factory unlocked, if i changed the logic board from locked iphone does it affect the unlock ???
- de
Agregar un comentario
3 Respuestas
OK
Still the same problem on dropping the iPhone 4!
The logic board has moved you have to unscrew it (ask the service shop people to do it) and tighten the screws again.
The screws grounding the logic board to the metal body are responsible for GPS, WI-FI, Second mice, GSM antena etc.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
thx i will try that and see what happen
- de
It does sound a loose connection. Do check all connectors to make sure that they are seated properly. Check on what Armald mentioned since it does sound like sound advise. Do other people receive your calls and how do they hear you? Just wondering if it is a speaker or a mic issue. Easy fix would be a lose connection....if you follow the guides on ifixit, you get step by step instructions and tips and tricks in how to fix your phone once you established where the fault is. Toughest part of the job is the trouble shooting. So the more information that you provide, the bigger the chance that people can help you out. Good luck
Puntuación 0
Comentarios:
the mic and speaker is fine ,when im playing song or tring to record something its goin well, but when im calling here comes the problem , i hear cracking sound so i vibrate my iphone with my hand during the same call and vola its working fine and sometimes it goes without any sound "even the cracking sound goes"
thats my case if u want to ask me anything u r welcome :)
- de
So shaking the phone makes it better? Sounds like something is lose. I would definitely check for a lose connection. The metal band around your frame is nice and tight and not broken or cracked? I Will check some more and let you know as soon as I find something. Can other people here you without static?
- de
when its working i can hear and talk with sometime cracking sound , when its not working i cant hear and no body hear me in the other side
seems to me something its not connected well but which cable :)
- de
First I found this iPhone 4 Microphone Teardown then I did a search on Google and was amazed. Looks like lots of people having problems with the mic...but your requested info is right here iPhone 4 Logic Board Replacement step 18 shows you the connectors. Hope this helps
- de
!!#* i got the same problem here,
But everytime the cracking noise happends, i open up the iphone, disconnect some cables and reconnect them then it works again.
But the next day cracking sound comes back!
Redo the whole thing again, works again? Weird...
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 18,727
