Replacement battery is causing apple hardware test error
I purchased one of your replacement batteries in part because my old battery no longer holds a charge and because the Apple hardware test stops at a battery warning.
I'm not sure if the full test is being performed. The replacement battery I purchased from you is also causing the Apple hardware test to have an error code 4xxx/4/4000005: "Battery"
I'm unsure if the full hardware test fully completed or not since something else is wrong with my computer.
Es esta una buena pregunta?
