Saltar al contenido principal
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Preguntas 532 Ver todo
Ipad Air wont charging and turn on
Charger connected when not show any screen, not reponse
I checked rails
PP3V0_S2R_TRISTAR : 0v
PP1V8_S2R_TRISTAR : 0v
PPVBUS_PROT : 4.4v
Ppvbus e75 usb conn : 4.4v
Help me please
Sorry I cannot speak english well
Update (03/07/2017)
I checked VCC MAIN
VCC MAIN : ALL 5.2V, NOT SHORT
and PP3V0_S2R_TRISTAR , PP1V8_S2R_TRISTAR line
checked
but all capacitor not short, volatage is 0
upload several pictures,
check please
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
Add
WLED LX A,B : 5.2V (datasheet :20v)
PPLED OUT A,B : 5.2V (datasheet :20v)
PPLED OUT BACK REG : 5.2V(datasheet :20v)
Measured value is lower than the value of the Regulation
U8100 problem?
- Por
Replace the tristar. It is very chipped and probable damaged.
- Por
Check if the WLED and PPLED lines are shorted to vcc_main.
- Por
Agregar un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
3 Respuestas
Solución Elegida
The TRISTAR voltages should not read 0V.
Those voltages are being driven by the PMIC (U8100). You will need to determine if the 0V, probably caused by a short somewhere along the line, is due to a faulty PMIC, faulty Tristar (U6000) or a bad capacitor along the line.
UPDATE (2017-03-07)
I saw your update on the measured voltages. It would appear that the LED Buck Converter is not doing its job. This is caused by either defective passive components, such as the coil and diode (these are easy to check), or it is a defective PMIC. Considering you have other voltage issues (i.e. Tristar), I would lean more towards the PMIC. However, given that the PMIC is much harder to replace, you could try changing Tristar first to see if that solves the problem.
I would also probe all of the output voltages on the PMIC to see if there are more problems.
Fue útil esta respuesta?
Puntuación 4
Comentarios:
Thank you for your kind reply. "What is mean I,E? I'll check it.
- Por
Hi,
Can you explain or give me more information about the LED Buck Converter? What is this?
- Por
Are those going into or coming out of the tristar? Test for vccmain, and short to ground on those pins. Also will it power up with a known good battery?
Puntuación 1
Comentarios:
I'll check it.
- Por
solved ? this problem ipad air ?
Puntuación 0
Añadir tu respuesta
Chulsunpark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 61
Todo El Tiempo: 1,890
