Saltar al contenido principal
Battery not charging after I changed it
Hi, I replaced my old battery with a new i bought here. After I replaced it, Iphone 5 turned on regularly and cherged til 40% . I went to sleep and let it charging, but at morning I found the iphone 5 turned off with 0% battery and now it is not charging anymore and doesn't turn on cause the low battery. I tried 2 different charging cables but it has not changed. can someone help me ? thx.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
2 Respuestas
Solución Elegida
What was wrong with the old battery? Was it that it drained to 0% and wouldn't charge or suddenly shut off at certain percentage or stopped working?
If it does not charge a flat battery then the U2 tristar charging IC chip needs to be replaced by someone that offers micro soldering.
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
Hello, change the charge socket first.
You can see how to change it from here
You can get it here
If not, you can try changing the battery
You can get the battery here
You can look at how to do it here
'''If this is not the case then the power integration is also a problem. If you can take a master repairer, you will do it easily.
Imagen iPhone 5 Replacement Battery
Producto
$29.99
Imagen iPhone 5 Lightning Connector and Headphone Jack
Producto
$24.99
Imagen iPhone 5 Batería
Guía
Reemplazo de la batería del iPhone 5
Dificultad:
Moderar
15 minutes - 1 hour
Imagen iPhone 5 Conector Lightning y toma de auriculares
Guía
Reemplazo de conector Lightning y toma de auriculares del iPhone 5
Dificultad:
Moderar
1 - 2 hours
Calificación 1
Comentarios:
thx. the old battery was working wrongly. the percentage gone heavily down using it little bit, or shut off when it seems that was charged.
por
Ah then that's the battery most likely. Have you checked the charging cable if it plugs in fully with no gap and have you tried another charger port?
por
yes, i tried 2 different cables, and cleaned the dust but nothing happens. The strange thing is that after I've changed battery it was charging right, then I don't know what is happened because i found it turned off.
por
Añadir tu respuesta
Gianluca De Dominicis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 79
