Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2688 Ver todo
Which part tells GPS which way phone is pointing?
The GPS locates me fine, but when I'm in motion, the arrow indicating my direction of travel is ALWAYS off, usually by about 30 degrees counterclockwise.
I've tried recalibrating the compass and turning location services on and off over and over again... no dice.
So I figure perhaps there's a part I can replace that would solve this problem, but I don't know which part!
Thanks!
Es esta una buena pregunta?
Puntuación 1
1 comentario
Just saw this and had to laugh a bit: Astonishing geomagnetic spike hit the ancient kingdom of Judah. So you can see our dependance on even the simplest mechanical compass may not even work!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Its possible the chip it bad but thats beyond what you can fix as a DIY. More likely you may have something magnetic on you or near you thats influencing the compass.
To understand whats happening here lets review how your location is known:
  • The GPS only shows your location longitude and latitude, it's not that precise due to the way its designed.
  • Your compass tells you direction but its based on magnetic north, not true north (in the northern hemisphere). So again it's not that precise.
Both have additional computations to aid them in their precision.
  • In the case of location, cellular towers are used as well as WiFi AP's which are static and have been identified by multiple GPS systems in their travels.
  • In the case of the compass, it leverages GPS to know the distance variation of magnetic north and true north so depending on your area a fudge value is modified. One of the problems we have is magnetic north is moving! Here's a bit more on this: Wandering of the Geomagnetic poles. So the fudge factor used can be off and as you get closer to the equator the factor error can be off by quite a lot.
If you are sure by using a second iPhone or other electronic GPS/Compass as a reference I would visit an Apple Store to have the phone serviced.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Thank you for the thorough reply!
To be clear, then, it's the compass functionality that is likely causing maps apps to think I'm driving sideways?
And if this is the case, my compass app should be off compared to a real compass (or working one on another phone)?
And if my compass is misaligned, that's something to bring to Apple for a fix?
Thanks again!
- de
Since you are moving the ring of the area the GPS system thinks you are within can be off a bit. Here's a bit more on it: How accurate is GPS?
The position you are in relation to the map app may not be correct, hence you see your self tracking in parallel of the road not on the road!
So to be clear here running in parallel is a GPS processing error within the phone not a compass issue. Often this is do to a moisture issue messing up the timing circuit within the phone.
It will need to be serviced by Apple or Apple authorized service center.
- de
Ok I fear I've not been clear... the gps positioning is great. Spot on.
The issue is instead that the directional arrow--the little thing attached to the blue dot that's supposed to tell you which way you're facing--points off the side of the road.
GPS knows exactly where I am on the road, it just seems to think I'm moving down that road sideways.
So it seems the GPS chip and whatever is used to locate me is working great, it's *just* the directional arrow that's always wrong.
Does that change your calculus of what might be wrong?
- de
Añadir tu respuesta
Jason estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 301
