Saltar al contenido principal
Reparar información en unidades de disco o discos duros. Los discos duros son dispositivos magnéticos de almacenamiento de datos. Se utilizan en la mayoría de las computadoras de escritorio, portátiles y servidores debido a su bajo costo y alta densidad de datos.
Preguntas 143 Ver todo
How do I reposition the spindle of my hard drive on my laptop
whenever i boot up my laptop, the hard drive clicks 8 times. and im positive that it is because the spindle is stuck, and needs to be repositioned... and im wondering hwo to do that
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Spinning disks are typically 2.5" using a SATA connection. Without knowing what your system is we can't guide you any further.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You can't fix your drive without having a clean room as any dust allowed in will kill the drives heads.
At this point its best to just replace the drive.
Fue útil esta respuesta?
Puntuación 2
If it clicks 8 times on turn, it doesn't mean the spindle is stuck. It means there is an area of hard drive frequently accessed on a start up that it is having problems reading. 8 clicks or so means its retrying to re-read.
It is strongly suggested you replace the hard drive. It may even be a good excuse to get one those new fangled SSD drives.
Puntuación 2
3 comentarios:
K... should I get m.2, pciee, or sata 3? Considering it's a laptop... I'm thunking data... but I'm not sure how I would install the m.2 or pci ssd
- de
Hi @marko1 ,
Look up your exact laptop specs to determine what type of HDD connection it has. You may only have the one option
- de
Can you get the model number from device manager? I can tell from that.
- de
Añadir tu respuesta
marko webb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 171
