Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
No image on lcd after touch IC replacement
I have a customers iPhone 6 that had touch issues. The problem was not the screen but was on the motherboard. I changed touch IC U2402 and after process finish the lcd shows no image. ITunes recognize the phone, I can handle the phone through my pc, I can make a back up etch. But I don't know what I did wrong and I can't see the lcd image. Backlight coil is from the other side I don't think this is the problem. Can someone help me where to look on motherboard; thank you
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Solución Elegida
I would also suspect the backlight circuit (just shine a torch on the display and check if you can see the lcd image) . As already stated, when applying heat to a board where the components are so close together, the chance of disturbing an unwanted component is extremely high and there is an equally high chance of effecting the backlight circuit. When soldering Smd parts, I always use captan tape surrounding the component in question to reduce the chance of heat spreading to unwanted areas.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I think the problem is the backlight driver. This chip is exactly from the other side of the board where i heated. I cleaned the glue around the chip and removed from his place. I will order a new chip and when i will install it I will post the result
- de
Do you have the result friend? I have the same problem and must to change the chip. CPU chip i think. I have heating tooo much.
- de
Respuesta Más Útil
Hi John. That is exactly your problem. Opposite the Touch IC's, on the front side of the pcb, is the backlight circuit. When you apply too much heat, you can either damage the backlight circuit or cause some loose solder joints.
You also have to be careful because the CPU is right there as well. Being stuck in place with underfill, there is always a risk that too much heat can cause the solder balls to expand and they have nowhere to go other than short each other or get exploded out from underneath.
Remove the shield over the CPU and inspect carefully for excess solder balls. Then inspect and probe the backlight circuit. You may have loose components or a defective backlight filter.
EDIT (2017/02/17)
Here are some snippets from the schematic. I would check the backlight circuit, specifically the diode, the decoupling capacitors and the ferrite beads (filters or some say fuses) on the anode and cathode side.
Puntuación 5
5 comentarios:
Thank you for your time, I remover the cpu shield and I don't see any solder balls, I suppose the broiler is the backlight circuit. Can you help me how how to check all the components of the backlight circuit. How can I know which component failed; how to test backlight coil;
- de
Hi John, see my edits in my answer.
- de
Thank you so much. So you think the problem is on the backlight circuit?
- de
I had the same issue after rehot the touch ic and after that when I repaired again there was balls inside the touch ic I reball the ic and points on board and it’s working now
- de
IPhone 6/6plus
Sometime touch ic points on board are miss that’s why touch doesn’t work
- de
Friends,
I have replace the touch ic on my iPhone 6 plus. After replacing I have black screen with light but I cant see anything else. Can you help me dear?
Puntuación 0
4 comentarios:
i have the same problem... Have you figured it out?
- de
No nothing. I dont now what the problem is. They said you have heating too much. You must to change CPU. But which CPU?
- de
Did you guys figure this out I have an 6 Plus that I got with no touch functionality I replaced meson and the phone didn’t display any image on the screen, I removed meson and display came back up but no touch of course because I had no meson I have tried 3 meson IC I know they are good because I have tested them on another phone, but when I put meson on this phone I get no display, I get normal power drain from DC power and as soon as I remove meson it comes back up but no touch any ideas
- de
Hey did you happen fix the problem ?
- de
Añadir tu respuesta
johnfl21 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 9,906
