Saltar al contenido principal
La PlayStation Vita es el sucesor de la PSP. Contiene un procesador y gráficos mejorados, e incluye la adición de un segundo stick analógico. Fue lanzado el 15 de febrero de 2012.
Preguntas 160 Ver todo
Playstation Vita won't charge.
Playstation Vita won't charge. When plugged in a solid orange charging light appears for about a minute, followed by a single blue flash then no light. With the Vita on, you can see the icon does not reflect that it's charging.
I've tried 2 different charging cables.
Plugging into the Power Brick.
Plugging into PC with Vita in USB Power mode.
Nothing appears to work.
History: I recently replaced the battery myself. The replacement worked as the system works, but I have since noticed the charging issues mentioned above.
Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
Did you replace the battery due to the problem or just replaced it due to normal use? If you did replace the battery for normal use you probably just need to replace your battery again because you probably just put in a defective battery. If you replaced the battery due to the charging problem you probably need a new Vita.
- de
Agregar un comentario
1 Respuesta
Sounds like you need a new charging port
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
ArcadeDemon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 2,934
