How do I fix the wifi, it won't turn on
When I move the setting to wifi on, it just turns grey. The same happens with Bluetooth
Es esta una buena pregunta?
@tbow2k ,Tom. I found a suggested fix from a forum 1st link below, remove battery, hold down power button 30 seconds, reinstall battery and power on.
Other things to check would to be up to date on firmware. Link #2 is Samsung trouble shooting on WiFi etc. where you can input info. and hopefully get a solution.
Factory reset is probably the last thing you want to try, last link explains the process. Good luck.
https://forum.xda-developers.com/galaxy-...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 980
