TI-84 Plus calculator support.
Preguntas 10 Ver todo
TI 84 Calculator got wet from water. Won't turn on.
Changed batteries but won't turn on. What can I do?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Try these steps...
  • Open your calculator and remove the logic board
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Mae estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 9
Últimos 7 Días: 35
Últimos 30 Días: 125
Todo El Tiempo: 1,034
