A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure.
Preguntas 141 Ver todo
Why won't it go to the wash cycle?
It go's from fill cycle to spin cycle?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
it will fill and never to to wash or behond
por
I will need to pay the Lid Switch tomorrow, install before I know.
por
Agregar un comentario
1 Respuesta
Solución Elegida
This can be several different things:
The lid switch is the most likely part to fail in this circumstance. However, this is only the most likely and there may be another part at fault. Here is a short list of ALL the parts in your top load washer that may have failed (and caused your particular problem) in alphabetical order…
Cycle Selector Switch – The cycle selector switch controls the speed of the motor and if it goes bad it can stop the motor from operating.
Drive Belt – If the belt falls off or becomes worn the transmission will not turn and the machine will not agitate. The machine will make a humming noise as the motor will be running.
Drive Motor – This motor turns the agitator and drum to wash your clothing. If it goes bad the machine will not agitate.
Lid Switch – The lid switch makes it so if the lid is opened, the machine will not run. A bad lid switch will make it so power cannot get to the drive motor.
Timer – The timer supplies power to turn the motor. If the timer is defective, the motor will not turn therefore no washer agitation.
Water Level Switch – The water level switch (aka Pressure Switch) controls the water level. If defective the motor may not receive power.
These are the most likely parts that may have failed due to the issue we have explained above. Use safety precautions when doing any type of maintenance checks on your washer.
Fue útil esta respuesta?
Calificación 2
Comentarios:
I have a maytag bravos also it will not go to the wash cycle, it does add water, scenes, nothing after that, but it does agatate on the rinse and does spin on that cycle.
any suggestions.
por
my washer fills and goes to wash cycle but will not lock and go through the wash cycle
por
bernie sounds like a lid lock issue
por
Añadir tu respuesta
Rick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 11
Últimos 7 Días: 85
Últimos 30 Días: 438
Todo El Tiempo: 5,168
