Power steering fluid or ATF-4 for the power steering unit?
Es esta una buena pregunta?
Check the cap of the power steering fluid reservoir or possibly the side of the power steering fluid reservoir. There will probably be a sticker or raised/engraved letters indicating what fluid to use. Also, you can check the user manual-the fluid spec will definitely be in there.
Fue útil esta respuesta?
yes to Andrew, or call any dodge dealer. The oem spec is best if you want longevity, but if your penny pinching, and its a beater the ATF is fine. they are essentially the same, with slightly different additives.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 4,733
