Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1266 Ver todo
iFixit Replacement Battery Not Charging or Reading % right
Hi all,
I ordered the battery replacement kit for the iPhone 6 Plus and followed the replacement guide as closely as possible. I did run into trouble with the adhesive but eventually got the old battery out. When I put the new battery in, I found the connector didn't set very nicely, but I believe it connected, as well with the other connectors (the digitzer, etc) up top.
After reassembly I turned the phone on and was just happy to see it turn on successfully. After a few hours of use though I noticed the battery percentage wasn't reading right. It would keep flip flopping between numbers like, 12%, 9%, 12% again etc. I thought maybe a calibration would help, but when I let it charge overnight I noticed it didn't charge at all and stayed at 9% all night.
I'm really nervous and upset about this and hoping for some advice or help.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Solución Elegida
If you bought a bad battery from iFixit. Just hit em up. They're pretty good at honoring they're warranty. I think I've had to do this twice in the past year or two. They respond and ship IMMEDIATELY
Fue útil esta respuesta?
Calificación 5
Sounds like a dudd battery, id contact the vendor for a replacement, even official apple batteries can be faulty.
Calificación 4
Comentarios:
Went to a repair place today and the battery was swapped out for one they had. Worked perfect after that. I bought the battery from on here. Bummer. Thanks for the reply.
por
As rayeasom says, absolutely replace the battery with another one, preferably one that is known-good, perhaps from another device.
If it fails, it is indicative of a charging problem on your logic board and requires a micro-soldering repair.
Calificación 3
Añadir tu respuesta
Dalaney Vartenisian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 25
Todo El Tiempo: 320
