Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Can't turn it on anymore
Hi there,
I have an Mid2014 Retina and used it very often like 8-12 hours a day.
A few weeks ago I got the message to change the battery.
In my holiday (from EU to Mexico) my macBook worked for about two days and after that I can't power it up anymore.
I replaced the battery yesterday.
The MagSafe was showing a Orange light and today it's green. So I think the battery is fully charged. But I can't still turn it on!
What options do I have to get the MacBook running again?
I am not sure if this is a problem but the first chip on the SSD is getting a little bit hot when charging.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
I would open it up, and disconnect the battery and SSD and try to boot the laptop. The computer should boot, and show a blinking question mark folder. If this doesn't work, then there is very likely something wrong with the logic board and something will need to be fixed on there.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I tried this. But nothing happen. So there would be a problem with the logic board. The best option would be to buy a new logic board right? I don't think that this logic board is repairable.
- de
Welllll, technically almost any issue with a logic board is repairable, but it requires that you have a multimeter and soldering equipment. If you'd like to save some money, there are many stores that do component-level motherboard repair.
- de
You might need to do a SMC reset. It's worked for me in the passed when ive replaced batteries.
http://support.apple.com/kb/ht3964
Puntuación 0
Añadir tu respuesta
tais46 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 76
