How can I permanently disable wifi from the 2ds
on the 3ds there is an antenna . the 2ds doesn't have it
Es esta una buena pregunta?
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,236
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
- de Samuel Hilton
