How I reset the Throttle Position Sensor (TPS)
How do I reset my Throttle Position Sensor (TPS) in my Honda civic 2011
As reference: Optima idles high after Throttle Position sensor replacement.
Es esta una buena pregunta?
David Caballero , David, Maybe just try this first, unhook your negative cable on battery for 5 minutes or remove ECU fuse from under hood fuse box for 5 minutes, put fuse back or reconnect battery and this will reset ECU. If that does not do it, hope these links below will help, link #1 below TPS how to adjust and spec's to shoot for and a video showing how to set the TPS. Good luck.
Fue útil esta respuesta?
I got one for you I have a 2007 Kia Sorento codes p1295 and p161b and p2106 I replaced the throttle body no start and try to put the old one back on to get it to start no start on that one as well trying to find out why it won't start it was starting with the old one but now it won't start at all I was trying to see how to reset the throttle body let me know
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 65
Todo El Tiempo: 33,912
