The Alcatel One Touch Idol 3 features a 5.5 inch, 1080 x 1920 display powered by a 1.5 GHz processor.
Preguntas 98 Ver todo
Why my phone won't power on?
My phone charges and the light comes on to show it is charging but the phone its self will not power on
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 13
Agregar un comentario
9 Respuestas
Respuesta Más Útil
Issues w/ this phone have to do with the Android OS. The 1st issue is you have to hold the power button until it vibrates and comes on, 20 secs. Plug it in and WIFI connect because you're going to get a long download, reboot, etc.
Phone is alive but acts strange. Remove the case to disconnect the battery. This requires a YouTube video and a guitar pick.
https://www.youtube.com/watch?v=S-cUKzYj...
Disconnect the battery for at least 10 secs, then replace the upper right volume control plastic, and reassemble the two parts, pressing them together. Then hold the power button for 60 sec. The phone will appear to loose its mind often.
Now you'll have to deal with the "deep sleep" mode that triggers often, when it should simply "sleep". You'll need to install this "app", which is really a widget.
https://play.google.com/store/apps/detai...
This will help avoid deep sleeps that turn your phone off, and cause you to miss calls/have constant reboots.
Fue útil esta respuesta?
Calificación 1
Comentarios:
The youtube link isn't working
por
Here's a video link that does work: https://www.youtube.com/watch?v=yY8Gw1o4...
por
Just keep hold on the power button for 20 seconds and it vibrates and turns on no need of anything else to do i had try'ed this method and my phone turned on.
Calificación 1
Comentarios:
Brilliant, that worked, thank you
por
I am also experiencing the same issue with my Alcatel One Touch Idol X. :( I charged it with different charger brand, and when I turned it on again, it never showed anything on the screen. But, whenever I charge it, there's still a blue light. That light gives me hope. :(
Calificación 1
I have this problem too. Blue LED on the top is glowing while plugged in. But no matter how many seconds, minutes, weeks i hold the power button no signs of life whatsoever. Tried to contact alcatel but no replies. My warranty is expired too, so that's a pain in the ass. Could someone help me with this? Like a step by step how to bring back the dead? Thank you very much in the future.
Calificación 0
Comentarios:
I have the same problem :( When I press the power button, it vibrates every 5 secondes but never open!!!!
por
hello Ona Sapiel ,
Checkout these steps see if this helps -
first check the charger and charge it for 15-20 min using the original brand charger
than restart the phone and see if it turn on .
if not than try doing a hard reset on it . press the power key and keep holding it for 1 min
after all try changing the battery if nothing works take it to some store .
Please update me after trying this what happen next
thanks a lot ...
Calificación 0
I bought an Alcatel Idol 3s 18 months ago. Only used it for about 6 months. After that a fault came, now it keeps restarting by itself as soon as it reaches the home screen. With or without the charger every time it is the same. I was able to do a factory reset on it but to no avail. Can we do any thing else with it. Screen is cracked so probably warranty is void.
Calificación 0
I have a problem not answer my phone won’t come one at all kit had he light on when it charges and then when I try to turn it on it won’t work at all it is getting in my last nerves i just want to throw my phone across the room
Calificación 0
Hello my mobile alcatel pop 3 not turn on only vibrate then vibrate please solve it..
Calificación 0
Idk it just won't turn on at all even though the phone light turn on but the phone won't turn on
Calificación 0
Comentarios:
My friends phone is doing the same. Battery full and works on another phone. He did everything and nothing happened. He was texting and it just turned off. Please, if this site doesn't have an answer, tell us we are beat and buy a new phone.
por
Añadir tu respuesta
Nathaniel Price estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 39
Últimos 7 Días: 223
Últimos 30 Días: 1,266
Todo El Tiempo: 19,597
