Saltar al contenido principal
Procesador de 1.86GHz o 2.13GHz, almacenamiento flash de 128GB o 256GB
Preguntas 146 Ver todo
Will not start up
My MacBook air stopped recently and I have been unable to start it I Have attempted to reset the smc to no avail. I have disconnected the battery and attempted to start it will the power connected again to no avail. Is this an i/o problem?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Remove the logic board and charging board, and clean any liquid damage using 95%+ isopropyl. If you are getting a charger light when a charger plugged in, it is likely the trackpad cable (check both ends, if burnt or liquid damaged, replace), trackpad PCB (check for burns or corrosion) or most likely the keyboard.
If there is no light on the charger, check the I/O cable for burnt pins. It could be the I/O cable, charging board, keyboard (shorting PP3V42_G3H to ground) or PP3V42_G3H is not being produced on the logic board, or is being shorted to ground.
Clean any liquid on the board first, but take a picture of where it is corroded before cleaning. If no liquid on the board, most likely will be the keyboard, if the charger is lighting up and the trackpad cable is fine.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
William Hawkins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 328
