Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 757 Ver todo
So, any update on replacing displays?
Last I checked, about a week ago. Everyone here is saying there are errors with iPhone 7/7+. After a third party display replacement. Mostly with the home button. Which I noticed quite a few articles saying the home button messes up anyways. Also I noticed cpr saying their more than happy to do these repairs. I've been turning away and cautioning customers. Has anything changed?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Apparently the issue is coming from people using crappy displays, and it won't read things properly. So if you just simply use quality displays, there shouldn't be an issue
por
Agregar un comentario
2 Respuestas
Solución Elegida
I have just done a repair on an iphone 7 and the home button works fine, it is a very fragile part but as long as you are careful it can be removed easily. You need to push it through the front and feed the cable through and just put it back the same way in the new display assembly. The 7 is a bit more time consuming and difficult to repair than the 6 just go slow and be careful.
Fue útil esta respuesta?
Calificación 2
See the thread "Home button not working after installing new screen". Replacing the new LCD back plate with the original back plate resolves the touch ID issue
Calificación 0
Añadir tu respuesta
iMedic estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 663
