Saltar al contenido principal
The Motorola Razr V3c is a CDMA2000 version of the Razr.
Preguntas 8 Ver todo
#7 on key pad is very intermittent (3%)
#7 on keypad hardly ever connects. Verizon sprayed a cleaning product on the external keys. The key "clicks" but rarely makes contact. I like the phone. Repair shops quote $40 to replace the entire keypad.
Thanks for any input.
Joe
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
maybe try taking the plastic frontage off the keyboard and layering a tiny bit of tinfoil underneath it, so the contact has something to touch?
I've done this with other types of buttons before, I believe it might work for you. it's worth a shot, anyway.
hope that helps!
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank you!. Now I try then I tell you
- de
I would use the guide to remove the keypad and would clean the contacts under the adhesive that holds the half button - i never yould use something that could shorten anything inside a phone
- de
Añadir tu respuesta
jbass43314 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,491
