Revelado en 1999 como la computadora portatil de Apple para los consumidores.
Preguntas 302 Ver todo
can hear it power up, black screen
turn on the power button and can hear all the normal sounds just has a black screen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
3 Respuestas
Try connecting to an external display, if that works replace the display. If that doesn't work it could be the logic board.
Fue útil esta respuesta?
Calificación 0
Comentarios:
I'd try the cable between the logic board and the display first.
por
follow up question to QEII Student IT:
same problem hooked up external monitor, got secondary display and mouse but no dock or bar or anything now what? how do I mirror the secondary display?
Calificación 0
If you have not tried PRAM reset holding down [command] + [option] + P + R
Make sure it is powered on and use a flashlight and shine it through the logo on the back. Press the keys for launchpad or dashboard so you know something would be on the screen. When you shine the light through the logo if you can see anything, desktop, launchpad or whichever you attempt to open then it is an issue with the sleep sensor. Sometimes this is a silly fix but just slowly try and shine the light at all angles through the logo, I had this happen to me and the flashlight trick got it to come out of sleep mode. Otherwise let us know how it went.
Calificación 0
Añadir tu respuesta
mas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 1,138
