Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 575 Ver todo
My iPhone 6S+ camera won't stop shaking?
The camera on my iPhone 6S+ has recently begun shaking uncontrollably for absolutely no reason whenever the app is open. Video timelapse, everything is affected the same way, no matter what app is used. I've scoured the internet looking for others having the same problem, and I have found plenty of *6+* users but no 6S+ phones affected. Does anyone have a quick fix or do I need to send the phone back?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 12
Comentarios:
Same issue happening here. I can actually hear the lens stabilization failing. I have a appointment at Apple on Friday. I am out of warranty but I am hoping they replace as my rear camera is completely useless now. Also in a separate issue, I have seen a significant performance drop recently. Fingers crossed.
por
Same issue happening to me. Did you resolve?
por
Hey guys did you fix the camera?
I have the same issue for my 6s+..
por
I brought it in to Apple and they wanted $55 for repair, which they said may or may not actually fix it. I am a bit !#^&@@ they couldn't provide me with a camera that lasts two years, so I declined to give them more money. I can wait until I pay this off and upgrade.
Sidenote, I have had iPhones since the 1st gen and this model in particular has been the absolute worst in terms of bugs and now severe hardware issues.
por
I fixed the problem!! I hope it works for you guys, but just tap repeatedly on the back of your phone where the camera sensor is, hard, but not to hard to damage the camera.
por
Mostrar 29 comentarios más
Agregar un comentario
14 Respuestas
Solución Elegida
Well, Apple does have a program, replacing these cameras for 6+. You could ask Apple if they'd be willing to do it for yours
Thank you, Uncle @mayer
https://www.apple.com/support/iphone6plu...
Fue útil esta respuesta?
Calificación 8
Comentarios:
Do you have a link to that program?
por
dude hes talking about 6S+
por
Ok person that can't be identified, they still have a program for it. And thank you again @mayer my answer is way better afteer your suggestion
por
Were you successful in having your phone repaired or replaced?
por
They are not willing to do so. (source: I called Apple about this issue this morning and they told me the 6S+ does not qualify.)
por
Mostrar 5 comentarios más
Any updates? I have the same problem
Calificación 1
Comentarios:
Same problem here. But I never updated the iOS cause I don't have enough memory.
Does Anyone have a solution to this problem?
por
Same problem this sucks
Calificación 1
Here is something interesting. After I updated to IOS10.3.3, this issue happened.
Calificación 1
Comentarios:
Same thing happened to me when I updated IOS, but to iOS 11 beta. I pretty sure it’s the optical image stabilizer because when I use 3rd party apps the camera is fine.
por
Just try a third party app and turns out the problem cannot be solved
por
Called Apple they are acting like they’ve never heard of this problem on the 6s+. They replaced the camera and still shaking, said I need to pay $300+ to fix it. Clearly I’m not the only one my phone also started after ios11 and the magnet on the front fixes it. So it will remain taped on. Apple needs to admit they have a problem and fix them for free
por
por
Same with my iphone 6plus.. I check in apple if my phone is eligible..Upon clicking,,it was replaced and not eligible. Is there's any solution so the shaking camera disappear. Do i need to replace the camera. Please help me on this.Thanks
Calificación 1
Comentarios:
I had this issue with my 6S+ as well. I had AppleCare, but my warranty was expired by a few days. Apple employee told me that the 6S was not part of the eligible program affecting the iPhone 6. They offered to replace my camera anyway, and now my phone works fine.
P.S. - My phone is jail broken so I originally had concerns it might be software related, but it definitely appears to be hardware. Removed my jailbreak and restored my phone before taking it in. They did not update my phone or ask about jailbreak. Hope that helps anyone interested...
por
How did u jailbreak and what software did u use can u email it to me pleaseeee vmsouva@gmail.com
por
I have the same issue, tried tapping the camera area in all ways, still didnt work. But i found this solution somewhere in youtube, Put a magnet on the opposite side of your front camera (top right of the screen you are looking at right now) the magnet, will magically, drop diamonds from the sky lol
Calificación 1
Comentarios:
It works for me too
por
THIS TOTALLY WORKED!!!! Thank you so much!!
por
Awesome! Worked for mine as well!!
por
For $15 just replace the camera. It fixed the issue.
Calificación 1
Comentarios:
Thank you for the $15 most helpful explanation
por
It didn’t fix mine. We installed 2 different rear facing cameras, (new of course) and instead of shaking they were just black! We watched the instruction video several times before removing the old camera and followed directions to the tee, but nothing but black! We removed it and tried again but once again it showed just black. We returned it and ordered another new camera from a different vendor (both vendors had high ratios and both cameras were OEM) but the exact same thing happened! Each time, when we removed the new camera and put the original camera back in, it would go back to shacking and blurriness! Bizarre!
por
It could possibly be that you hit the sensor of the camera while replacing it
por
So interesting i put a magnet in front, on the upper right hand of the screen just opposite the rear camera and it completely stops the shaking. My camera works just like new! I got the magnet from an old ipad case (you know the really thin ones, and coin sized.) cut it into a smaller piece And stuck it underneath my iphone case and voila! The shaking is completely gone! Just a temporary fix anyway until i get a new phone some time in the future.
Calificación 1
Comentarios:
Thanks. It works for me too. As soon as a magnet comes close to the front side of the backside camer the shaking stops. Strange but a cheap solution :)
por
See my permanent fix somewhere here. Guaranteed to work.
por
I downloaded a third party camera app and it works fine. The one I downloaded is called MuseCam. That makes me believe the issue is somehow software related rather hardware. My lens is shaking so hard when using the original Apple camera app that I can here the shaking noise. Like if there is a fly caught inside the phone! Looking at the lense closer also reveals how violently it is shaking.
Anyways, from now on I will use that third party camera app.
Material:iPhone 6S+. 128Gb. iOS 11.3.1.
Calificación 1
Comentarios:
Does the MuseCam app let you shoot videos? or just photos?
por
Just tried this app , shaking still there but not so violent.
Pictures ok.
por
I have an iPhone 7 and my camera looks like it's just vibrating or shaking. Is there anything I can do to fix it with out calling Apple
Calificación 0
Comentarios:
tap the camera with your fingers a few times it MAY solve the problem some time
por
Does replacing the rear camera fix this issue?
Calificación 0
I had a client come in yesterday and had the shaking camera. Upon closer inspection of the functions of the phone, I found the compass wasn't reading correctly. I used a magnet as suggested by @Gibbz Arcilla and it fixed the shaking camera and the compass. I believe it is a board level problem. The customer did use the magnet for the future so I was unable to diagnose the actual problem. Side note the phone was ripped apart when I received it so it could be anything. As soon as you reboot the phone or close the application the problems come back. So my customer is going to tape it to the glass.
Calificación 0
Purchased a tempered glass case that fitted via tiny magnets ,not cheap approx 32$ .
This has proved to have caused the wobble on my iPhone 6s Plus .
Awaiting reply from supplier for a refund
Calificación 0
Comentarios:
Ma iphone7+ Camera shakes when am trying to take a photo.. pls is there any solution to this
por
Remove the phone case/cover or adjust it and it will stop
por
meet the same trouble
It is so cool to enjoy movies on weekends; much cooler is to watch the movies on a large screen lying down on the bed or sofa. Now, many movies online are in MP4 format, then read it to learn how to burn MP4 to DVD/BD by yourself. You can be assured that it is very easy to operate.
Calificación 0
Añadir tu respuesta
Lincoln Hoffman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 610
Últimos 7 Días: 3,984
Últimos 30 Días: 16,735
Todo El Tiempo: 178,304
