Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 731 Ver todo
Why is my MacBook freezing and heating up?
Hi,
My mid-2010 MacBook is starting to overheat, and according to the temperature sensors, the CPU is hitting 100+ degrees Fahrenheit. I ran the AHT, and it can't get past the RAM test without locking up. Is my heatsink damaged, or is the motherboard FUBAR?
Thanks!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
Solución Elegida
Well if it can't get past the RAM test, that where I would start.
Update
Will it boot all the way up? It so go under the Apple to about this Mac> Memory and see if it is seeing what's installed. If it is not seeing all of it, reseat the RAM.
Next open it up and blow it out. If it is heavy on the dust, remove the fans and clean the vents. Here's how:
MacBook Unibody Model A1342 Fan Replacement
Now boot the Mac with the back off and insure that the fan is running.
If it is still running hot we need to look at the heat sink and thermal paste replacement. This model uses a liquid filled heat sink that can develop a leak. So when you go to replace the paste look on the logic board for traces of an oily looking stain. If you find it, replace the heat sink.
MacBook Unibody Model A1342 Heat Sink Replacement
Como aplicar pasta térmica
Arctic Silver Thermal Paste
Imagen de Arctic Silver Thermal Paste
Producto
$8.99
Imagen de Electronics Skills
Guía
Dificultad:
Fácil
5 - 20 minutes
Imagen de MacBook Unibody Model A1342 Fan
Guía
Dificultad:
Moderar
10 - 30 minutes
Imagen de MacBook Unibody Model A1342 Heat Sink
Guía
Dificultad:
Difícil
Fue útil esta respuesta?
Puntuación 4
Comentarios:
Well, how should I check it? Is there a program I can get to do it?
- de
It sees all of the RAM. I've confirmed the fan is fully working, so I'll check the heatsink when I get a chance. Thanks!
- de
Añadir tu respuesta
Nikola Wozniak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 30
Todo El Tiempo: 527
