Saltar al contenido principal
El Xbox original es el primer sistema de videojuegos de Microsoft. Tiene una carcasa negra fácilmente identificable con 'XBOX' blasonado en la parte superior y frontal. La reparación es fácil con herramientas comunes.
Preguntas 152 Ver todo
Why won't my console turn on?
I had bought a preowned original xbox on Lukiegames and the system had worked fine for awhile but today it just suddenly refuses to turn on when I press either the tray button or power button. What is wrong with it and what do I have to do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Hi Sacatuki! Does the Xbox display any sort of indicator, such as a sequence of flashing leds on the power and eject button, or an error code on screen?
Try powering on the Xbox with a different power cable, on a different outlet in your home. This will rule out a faulty power cable and/or faulty power outlet. The Original Xbox uses a generic IEC cable - you most likely will have another device that uses the same cable, and if not they only cost around $4. If it still doesn't work after that, most likely your PSU has gone bad and needs to be replaced.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Ur idea is garbage, is not cable is xbox inside power supply.
- de
Añadir tu respuesta
Sacatuki estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 86
Todo El Tiempo: 2,662
