Does the surface pro 3 kick stand come with a hinge
The 2 little metal hinge connecting the kick stands are broken, Does the kick stand come with the hinges or can you post it with the hinge if possible.
Thanks!
Es esta una buena pregunta?
Thanks!
Honestly, I would just get a case that has a kickstand.
UAG has a case with a kickstand. I am sure there are others out there.
Just getting to the Surface's kickstand requires disassembling the entire device.
Even then, I don't know if the kickstand is repairable.
Fue útil esta respuesta?
I use the UAG case with the Microsoft surface Pro 3 and it is pretty good.
Covers the corners and around the screen really well without blocking air vents or ports.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 768
