How I can change the charging port?
Hi
I have some problem with my charging port..
I want to know if their is simple way to change it with new one
Thank you
Es esta una buena pregunta?
Hi
Thank you
The charging port on this tablet needs to be soldered in . Its not to hard if you have access to a heat station and soldering equipment. This video can help.
https://www.youtube.com/watch?v=4mcXJVbK...
There is also a teardown guild here
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Hope this helps
Fue útil esta respuesta?
So there is no way instead of using soldering equipment??
only if you replace the entire board
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 98
2 comentarios
@dr_shoaa , more info. there are probably 20 models, what is yours? Help ifixit help you!
- de L Pfaff
@lpfaff1 SM-T231 ( Galaxy Tab 4)
- de Shoaa Altalhi
