Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2,4 GHz, 2,7 GHz o 2,8 GHz (Turbo Boost de hasta 3,8 GHz) con 6 MB de caché L3 compartida.
Preguntas 274 Ver todo
Where I can find the OEM Battery?
I want to know where I can fin the OEM replacement battery for my Macbook Pro 15 Retina Early 2013 A1398 . I saw one on this page but is out of stock but I still don't know if it is compatible with my model any help please.
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
3 Respuestas
Solución Elegida
It’s currently in stock and also carries a 1 year warranty!:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Imagen de MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Producto
$79.99
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Yes, but I said OEM. I see several complaints this isn't good as OEM.
- de
Then you'll need to visit Apple and let them fix your system. No one offers new OEM batteries (other than Apple). You could find a used battery and that's about it.
- de
You won't find an OEM battery for any Apple computer unless it is taken from another computer. Apple does not sell parts to their products, I would assume, because they want you to pay the costly markup of them fixing it for you.
I highly suggest giving the new one (it is stated to be up to OEM Specifications, otherwise just as good, if not better, than the original Apple part) on this website a try - I did, and it's working great. The repair process was rather tedious and lengthy, but worth it if you don't want to invest $2,300 or more on a new MacBook Pro. It was also for an A1398 Model, Early 2013 15" Retina.
Puntuación 1
@elvisgonzalez I found this and says the brand is apple and the guy has a 99.2% positive feedback.
http://www.ebay.com/itm/Original-OEM-Bat...
Hope this helps!
- Jainore
Puntuación 0
3 comentarios:
It says out of stock and it says doesn't fit 2013 models but thank you!
- de
I think that one would not fit my mackbook because its late 2013 :/ and mind is early 2013 but thank you for trying to help!
- de
Añadir tu respuesta
Elvis Gonzalez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,499
