Saltar al contenido principal
Esta Nintendo DS Lite se lanzó en 2006 como sucesora de la Nintendo DS. Entrar dentro de este dispositivo es simple, lo que facilita las soluciones.
Preguntas 314 Ver todo
Pitch Black Screens on my DS Lite: Solid Green Light Remains
In the past year, I began to revisit my DS Lite. I had not used in over four years and it failed to turn on at first. However, I temporarily fixed the problem by hitting the DS again the butt of my palm. The problem reappeared and I realized that if it pressed hard on the bottom left corner of the screen the DS would freeze. The problem continued to occur but I solved it each time by hitting the bottom of the DS under that corner of the screen. Unfortunately, I recently broke the power button on the same DS and had to open it up to remove the switch. I turned it back on, hit it a few times and Voila, it was working fine for about ten minutes. Now, my previously effective method is not working and I cannot find anything amiss inside the DS. Any suggestions?
P. S. Don't just say "buy a new one"
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
You should get the screen replaced
Fue útil esta respuesta?
Puntuación 0
why is it black the screen
Puntuación 0
Añadir tu respuesta
Rowan Wiley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 529
