How to change Nikon bayonet lens attachment
I have two lenses both with the lame mount my better lens has chipped on the mount and the other lens is broken so i want to switch the mounts
Es esta una buena pregunta?
James, if it is the base rings/mount you want to change, make sure you match them up to be the same and unscrew. Make sure to install in same position on lens as was. Links below shows how to. Good luck.
https://www.youtube.com/watch?v=Pd6pvvQ1...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 179
