Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 4.7" es la versión más pequeña del iPhone 6 Plus. Identificable por los números de modelo A1549, A1586 y A1589.
Preguntas 4941 Ver todo
What is (unknown error 56) iPhone 6
I am getting unknown error 56 on an iPhone 6. I have used three different computers. I changed out the screen on this phone but I did retain the same home button. The phone was working perfectly fine up until trying to upgrade to 10.2. Thanks for any help.
Es esta una buena pregunta?
Puntuación 6
Comentarios:
i also have the same issue error 56 when try to upgrade to ipsw 10.2 and now 10.2.1 is out still same.
- de
Agregar un comentario
6 Respuestas
Solución Elegida
According to the iPhone Wiki:
''Error 56
Most likely a dead/glitched Touch ID sensor. If seen on iPad's, try restoring the latest firmware in DFU mode. If error still occurs, bring your device to Apple. On iPhones, take out the SIM card and try restoring in DFU mode. If still occurring, bring your device to apple.''
Fue útil esta respuesta?
Puntuación 6
its due to a fault nfc ic
Puntuación 1
Comentarios:
That is wrong, NFC fault is error 53.
- de
@pccheese it's still an answer even so we may think it is wrong. Not a good choice for a REMOVE AS NOT AN ANSWER vote. ;-)
- de
I can confirm error 56 gone after NFC reflow or reball
- de
I second this. U5301_RF reflow solved it.
- de
I have the same issue, but the strange thing is that my iphone 7 plus was working. when i tried to upgrade to the lastest ios, i got stuck in recovery mode..... does your fix still apply????
- de
Error 56 occurs when you try to update or restore your I phone with a hardware glitch. once occurred 90 % cases your phone needs an I C (U5301RF) change. 10 % cases it can be solved through updating itunes, turning off your anti virus, removing other USB devices from your computer or restore with another computer.
Puntuación 1
Comentarios:
- de
I have an SE with same error after trying to restore phone had been dropped and has evidence of previous water damage . Does the SE suffer the same chip/hardware failure ?
- de
1. check the usb port
2. close all unnecessary third-party softwares
3. restore your iphone on another computer
4. update your idevice in dfu mode
5. send your idevice to apple device repair shop
Puntuación 1
ifixit actually has a video on this that i had a similar issue earlier in the week. it is explained here in their video
https://www.youtube.com/watch?v=8IEWAQiu...
Hope it helps!
Puntuación 0
Please try this steps:
1 - Install the latest version of iTunes on your computer,
2 - Make sure your iPhone is updated with the latest version of iOS,
3 - Switch on your iPhone with a SIM Card from a non compatible network,
4 - Connect your iPhone to your computer using the Original USB Cable,
5 - Launch iTunes & wait until iTunes detect your iPhone,
6 - Now disconnect your iPhone and reconnect it after 10 seconds.
Make sure to back up first your files.
Puntuación 0
Comentarios:
I have a SE with the same error code , is it likely to be the same failure . Phone had suffered screen damage and has evidence of previous water damage . Phone was being restored because it was in disable mode due the defective screen.
- de
Añadir tu respuesta
Garry Anderson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 46,352
