Saltar al contenido principal
Why is my rpms running high when I start to accelerate slow?
My 2005 Nissan Sentra runs great except when I start to accelerate to get speed, my rpms rev up and you can hear it. I try to coast as much as possible. I only drive no more then 5 miles a day no faster then 40 mph.
Es esta una buena pregunta?
Puntuación 2
Comentarios:
I have a 2015 chevy impala ltz that all of a sudden the engine revs too high when I take off or when the trans shifts. sometimes it revs as high as 5000 rpm
- de
Agregar un comentario
5 Respuestas
Solución Elegida
I can't be very specific but in general, this symptom usually points to a problem with the transmission, or if you have a straight shift, it probably means the clutch is slipping. On automatic transmissions, the shifting is often done by hydraulic pressure based on engine speed. If the system fails, it may require high engine speed to shift to the next gear or it may not shift to the next gear at all.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
I have a 2014 Mercedes C Class auto, and when in drive, if I accelerate slowly,
the revs are way beyond to the gear I’m in. I have to stop the car, switch off and
restart the engine to reset the software.
- de
I have same problem with mercedes v class, i off/on twice to have it back normal
- de
Respuesta Más Útil
@dwdrummerswife , Christi, You should stop driving the vehicle if transmission is indeed slipping, as you are going to cause extensive damage and expense. Check the transmission fluid level and fill to recommended level if low. If fluid level OK, take vehicle into a good shop, have Tech. take a look, diagnose and estimate repair. Link below will show how to check transmission fluid level in automatic. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. https://www.carcarekiosk.com/video/2002_...
Puntuación 2
Comentarios:
Mine too is doing the same thing, but it's a 2005 Renault Clio 1.2 litre with a standard gearbox
- de
My car is doing the same Just got a transmission put in 2 days ago I drive freeway everyday If I go past 50 mph the rpm is over 4,000 you can hear the motor revn up loud Does this mean the computer just doesn't recognize there's a new transmission yet
- de
My car has been doing that too 2018 Toyota Camry LE whenever i go 40mph its at 1500 and 55mph its at 2000 and when i brake at a red light complete stop its at 750 wont go down to 0 unless i turn my car off
- de
I've replaced the coil packs on my plugs and it fixed the problem. No longer does it and sounds allot better. Try that before taking it to a shop first.
Puntuación 0
Comentarios:
Hi,just overhaul my automatic transmission,high revivving wen drving.
- de
And takes long to change gear,mech says must run it in.
- de
Could it just be our idles?
Puntuación 0
I got a 2001 sentra gxe and while in third gear I'd floor it and no movement whatsoever any ideas its a manual with about 213000 thousand miles when I purchased the vehicle I took it into jiffy lube to be serviced three different locations they all told me that my transmission drain plug was stripped and could not be removed any kind of knowledgeable information on this is greatly appreciated
Puntuación 0
Añadir tu respuesta
Christi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 168
Ultimos 30 días: 833
Todo El Tiempo: 161,455
