Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4252 Ver todo
phone screen flickering and/or vertical lines
The phone screen alternates between flickering in a light magenta shade and displaying vertical lines. Phone is completely usable, just now with shades of color tossed in the mix.
Sounds to me like a damaged LCD cable, but I haven't taken it apart yet. I've worked with electronics repair, just not iPhones. Point me to a guide?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Once any LCD cable or LCD gets damaged you pretty much need to get the screen replaced.
por
my phone has lines and is glitching and has green spots on it. I have the 8plus
por
Agregar un comentario
3 Respuestas
You may need a new screen or take the screen off and examine the connection cables of the ribbons and mother board. If the brass teeth are not perfectly aligned GENTLY drag a razor blade tip along then to realign them and CAReFULLY reconnect them
Fue útil esta respuesta?
Calificación 0
This could just be down to dirty contacts, you can try gently cleaning the contacts with a toothbrush whilst checking if any of the contact pins are bent or not aligned, you have to be very careful not to damage any of the pins.
Calificación 0
Took phone into Telstra and even they were dumb ass dumbfounded finally gave me new phone but I want to fix the other
Calificación 0
Añadir tu respuesta
Thor Kamphefner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 100
Últimos 30 Días: 393
Todo El Tiempo: 10,379
