Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 4.7" es la versión más pequeña del iPhone 6 Plus. Identificable por los números de modelo A1549, A1586 y A1589.
Preguntas 5040 Ver todo
Camera not working after screen replacement
Just after replacing the screen on my iPhone 6 I noticed how both the flash and video camera work perfectly, even the panoramic view has no problem but the camera does not work. The camera app doesn't show the screen because its all blurry. What did I do wrong and how can I fix it?.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
You may have accidentally disconnected the back camera while replacing your screen. A more common issue is, your front camera flex could've been damaged in the repair process. If the front camera goes out, it could cause issues with the back camera.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
How could I fix this issue?, im not really sure about that because I can still record but no pictures.
- de
i'm also going through a similar issue, my iphone seems to be seriously shoerted or something, It's draining up the battery and for some reason both the cameras and flash aren't working.
- de
Añadir tu respuesta
Marcelo Marquez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,427
