Keyboard mechanism retaining clips broken
I've been attempting to repair a broken key mechanism for a MacBook Pro 13" Retina (Late 2013, model A1502) which I've been given. When trying to reattach the mechanism to the keyboard I've noticed that two of the four retaining metal clips where the mechanism locates on the keyboard circuit board are broken.
I've uploaded a photo (see here), if you look at the bottom of the area where the key is missing you'll see that there are no clips. I've removed the down arrow and can see that there should be two sets of two clips.
I know the keyboard for the Retina models is part of the upper assembly so a swap out is no go. At the moment only the upper retaining clips are present meaning the key falls off easily. Does anybody have any ideas on how I can fix this so that the key stays on? The only ideas I have are to attempt to solder new clips on or to try and attach something to the bottom edge of the up arrow key to feed under the down arrow key.
I think this is unrepairable without spending £££ and lots of time but if anybody has any magic ideas they would be appreciated. Thanks!
Update
Thanks for the replies folks. I've marked up the original photo to show what is missing, it's the metal clips which stick upright from the keyboard base (they've broken off). I replaced the plastic butterfly clip on the key, it's only when I attempted to attach the key that I realised something was missing.
It looks like this is beyond repair balancing cost / effort. The solder suggestion was to attach fabricated clips but the chances of them lasting and the heat of the soldering iron not damaging something are slim. The best effort fix is to stick electrical tape over the key to stop it falling off!
Es esta una buena pregunta?
