Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1591 Ver todo
Doesn't wake up after sleep mode
Hi, iPhone 5c doesn't wake up after some time in sleep mode.
As long as it's in wake mode everything works normal. But when I press the sleep/power button it won't wake up after 5-10 minutes. Within 5 minutes it will wake up... After 5 - 10 minutes it doesn't turn on until I boot it up again .
There is nothing wrong with the buttons, screen or battery. I also can't find shorts.
Any ideas? Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
No water damage. software works and doesn't show Strange error in log files.
What happens inside the circuit if you press the sleep button? What power/data lines/chips shut down and have to start up once you press the power button again to wake up...
That's what I like to know..
I have the schematics.
- de
Agregar un comentario
1 Respuesta
Was it water damaged? Have you tried hard reset? This is known issue when the power flat was loosing contact, but you say it isn't hardware issue...
If software doesn't work, I would bet on motherboard problem...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Gordon De Clerck estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 97
