Saltar al contenido principal
El Toshiba Satellite C55-C5268 es un portátil de uso general diseñado para usarse con Windows 10. Fue fabricado por Toshiba en 2015.
Preguntas 10 Ver todo
Why won't my mouse buttons work?
The two mouse buttons on my laptop aren't jammed but when I click on something it doesn't respond. The touch pad above the mouse works fine and I can click on things with that but the mouse buttons still don't work. What is causing this problem and how can I solve it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There are a couple of reasons you might be having this problem.
First, make sure your laptop does not have a "disable mouse button" command. This feature can usually be turned on and off by pressing Fn+(F1,F2,F3, etc). If you still have the user manual you can check that for the specific command.
Another reason is a bit more intensive to check. The ribbon cable connecting the touchpad buttons to the motherboard might be disconnected, which would require you to remove the bottom cover of the laptop to reinsert. Removing the bottom plate is fairly easy, just follow the guide here. The cable you'd be looking for would be coming out of the back of the touchpad and leading to the motherboard.
The buttons themselves could also be faulty. This could happen over time through use, or if something got spilled on them. In this case your best option would be to replace or clean them.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ben Rounseville estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 602
