Vertical color lines appear when turned on
Multi colored vertical lines appear when TV is turned on - they disappeared after a few minutes but now remain constant
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
I am having the same issue. And its getting worse. What can I do to fix this?
por
@starkwolf30 what have you checked? Same TV as the OP? did you check what was listed in my original answer?
por
I have the same problem.
por
it might be a bad T-Con board
por
Agregar un comentario
1 Respuesta
Solución Elegida
Gerald Herd could be caused by corroded or loose ribbon cables as well as loose TAB's. Of course it can also be the T-con board. Post some images of what your screen looks like with your question. For that use this guide. It will allow us to see what you see. Also, it helps if you can tell us what you have checked thus far.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Gerald Herd estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 13
Últimos 30 Días: 73
Todo El Tiempo: 2,241
