Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1501 Ver todo
front screen cracked cant slide to unlock
front screen cracked and i cant unlock the phone to do anything at all is there some way i can unlock it other than using the slide that appears on the screen? .there is a new screen coming but it won't be here for a week or so .
thanks mike.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Hey Mike did it work after you changed your screen or did you have to do anything else to fix it?
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
6 Respuestas
Solución Elegida
if you cant slide to unlock then the digitiser is broken and all touch functions won't work. sorry but you'll just have to wait for the new screen.
Fue útil esta respuesta?
Calificación 3
Comentarios:
ok i was hoping that wouldnt be the answer but thanks . i'll just have to wait .cheers Mike
por
i have the same problem do you have to do anything else to have it fixed or just change the screen?
cheers
por
I cant get my iphone to unlock like at all i mean i can hit the home button but it wont let me play music or unlock or slide to unlock my phone what the !@#$ is goin on with my phone
Calificación 2
yeah but that's not true. the same thing has happened with mine, but i can double click the centre button to play music (touching the screen to press play and pause etc.). so the touch screen works, its just that specific part of the screen that doesn't work. there must be some way!
Calificación 0
Comentarios:
If there is a specific part of the touch screen that does not work, it is still your touch screen that needs to be replaced. Your touch screen is build with an "internal grid" and if it is broken at a certain area, that area will not function, while others do.
por
oldturkey is right here...any area not working can't be fixed apart from replacing the entire digitiser.
por
I have the same problem with my Huawie touch screen mobile, all I did is I asked a friend to call me and once I receive the phone i reply and hang off immediatly to unlock the screen.
Although its not at all a practical way to ask someone to call u everytime u need to use the phone but atleast it works.. So good luck till the screen is repaired..
Calificación 0
mine is badly crashed actually it was smashed in the car's door.
It doesn't unlock and the central button does not work, actually I-tunes does not connect it asks me to unlock it , I need to get some data from it... what can I do?
Calificación 0
My phone was cracked reallyyyy bad (a friends fault, not mine). When it cracked, everything worked perfectly. After a year (This is today) I took my phone in the bathroom with me and put it on the toilet while I took a shower, all the while my phone having a life proof case on. Then, when I went to pick up my phone, I dropped it. It did not crack anymore, but the touchscreen will not work at all. I mean, I can only use the home button, the power button, and the speakers button. I can see when people text me too. This is a big problem...... can someone help?
Calificación 0
Añadir tu respuesta
Mike Jeffery estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 21
Últimos 30 Días: 75
Todo El Tiempo: 75,647
