How to fix the charger port for a Sony SRS-X2
The charger port only charges in a certain angle and I was wondering if there was a way I could fix it without having to send it to Sony for them to fix it.
Es esta una buena pregunta?
Hi,
As there is a 1 year warranty on the speaker it may be better that you get Sony to fix the problem so as not void your warranty, if it is still valid. Although Sony will most probably reject your warranty repair claim saying that you caused the problem if it is found that the charging port has become dislodged from the circuit board- citing inappropriate user action or some such term.
If the warranty is no longer valid then you will have to open the speaker so as to see what the actual problem with the charge port is.
Unfortunately I have been unable to find anything online which details how to open the speaker.
There is this Ifixit guide for a Sony SRS-X7 repair which may be of some help in opening the speaker case, if they kept the design similar that is..
Sony SRS-X7 AM/FM Chip Replacement
Once you have the speaker case opened and have clear access to the charging port, if you need some help as to what to do next post some close up pictures of the affected area and someone will assist you further.
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Guía
Dificultad:
Moderado
5 - 15 minutes
Fue útil esta respuesta?
Thank you for finding this out and telling me how to do it. @jayeff
You're welcome. Good luck with the repair.
Have you solved the problem with Sony Jeremiah? It seems that I have the same problem.
I also have a non-functioning charging port. I do not see more replies to the above, is there more info available? Thank you in advance.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,448
1 comentario
Have you solved the problem with Sony srs-X2 Jeremiach ?
- de edyta.napierala@gmail.com
