Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Is this motherboard fried?
Hello there could anyone tell me if my motherboard is fried?
It looks like black stuff has dripped onto some circuits at the side of the processor.
I got the phone water damaged then cleaned it out with 100% alcohol done the same to the charger port ect all the connectors for the screen battery ect.
The phone powered up fine after that was doing everything it should then just cut out.
https://postimg.org/image/yrbtdlke7/
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
As Earl said, that is underfill. It's used to solidly hold delicate IC's to the circuit board and prevent water from getting underneath. It's not perfect but a very good solution for manufacturers. It's a pain to work on though for repairers.
The connector on the upper left appears to be damaged. Do you have continuity between the pins on the inside of the connector and the pcb pad upon which those pins are soldered. Sometimes the corrosion eats away at the solder joint. Otherwise, water damage can be very insidious, eating away underneath IC's.
You only show one side of the board. What does the other side look like?
Water damage is the hardest thing to troubleshoot because you don't know where all the damage is. What you see can sometimes be the tip of the iceberg. Focus on the connector for now. If you have a very fine point soldering iron and some experience, you could try and touch up those connections if needed. Only if needed...you can do more damage than good if you slip even only a few millimetres.
Otherwise, I suggest you find a repair shop that specializes in water damage and micro-soldering. The phone is not too old so you need to determine if a repair is worthwhile. Certainly if you need to recover data.
Fue útil esta respuesta?
Puntuación 2
that's probably underfill
Puntuación 1
2 comentarios:
What does this mean and can it be repaired?
- de
and get bga x rays too
- de
Añadir tu respuesta
John estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 594
