Saltar al contenido principal
Anunciado el 9 de septiembre de 2014, este dispositivo es la primera incursión de Apple en dispositivos portátiles inteligentes. Los manuales de reparación de iFixit son aplicables a Apple Watch (acero) y Apple Watch Sport (aluminio).
Preguntas 210 Ver todo
Use a display from the original Apple Watch for the Series 1?
Hey everyone.
I have recently broke my series 1 Apple Watch, and I am now looking for replacement Display-units. The device does still display things, just the glass is broken. I have found several ones, allthough they are all rather expensive. I just stumbled upon an auction for an original Apple Watch Display, which comes from the series 0 model. As its current price is relatively low, I'd like to bid as well.
I was wondering though: Is it possible to use the Display unit from an Apple Watch Series 0 for a Series 1? I does seem to have the same connectors, and I don't remember Apple mentioning any change of the Display when they issued the Series 1 Watch.
I would be really thankful for an answer to this problem, or at least some opinions.
Many thanks!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The display for the original Apple Watch and the series 1 can be interchanged as the only thing changed really was the processor speed. Ive also just doubled checked on here and both have the same screen/digitizer, Item Code: IF308-009
Hope this helps
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Many thanks for your reply, I really couldn't find a way of figuring this out. I didn't know one could search for parts on here, but now I do.
Also by the way, do you know what the little cable on the back of a Watch display with the three small solder points does?
Thanks alot in advance
- de
The cable on the back with the 3 small solder points connects the power supply to the proximity sensor.
- de
Wow, I did not know this. I am going to order a completely new display unit anyway, but is it possible to desolder that cable without damaging it? Just something I want to try.
- de
Yes it's possible to remove to cable without damaging it. Just apply a little heat to each point while slightly lifting the cable and it will come straight off (no need to apply any additional solder)
- de
Añadir tu respuesta
Daniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 378
