Saltar al contenido principal
Las chaquetas de plumas te envuelven en un suave calor, aislando tu núcleo de las temperaturas heladas y el viento. Son extremadamente comprimibles, extremadamente ligeras por su calidez y ultra cómodas para el uso durante todo el día.
Preguntas 40 Ver todo
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
- de
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Here's the guide on zipper repair for the Patagonia:
Installing A Main Zipper In Your Patagonia Down Jacket
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
Puntuación 2
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
Puntuación 1
Añadir tu respuesta
villemitikka estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 5,643
