The Samsung Galaxy J1, released January 2015, model number SM-J100VPP.
Preguntas 97 Ver todo
My phone won't turn on
Hi, when I try and turn on my phone, it jut stays in the "Samsung" page. I even left it over night, but it's the same
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 16
Comentarios:
Hi my 2015 j1 wont charge keeps saying use samsung charger iam i have cleaned usb port with that spray stuff
por
Hi,my Samsung Galaxy j1 ace phone hung and suddenly went off and has refused to come on...For about 24hours now..... What do I do?
por
Agregar un comentario
5 Respuestas
Solución Elegida
Or if you do not want to lose data flash correct firmware from sammobile via odin software and hope that it boots. If it doesn't boot then wipe+data / factory reset will be done which requires losing all user data on the phone.
Fue útil esta respuesta?
Calificación 9
Comentarios:
I already did it. but again it still does not open. why is that?
por
Stuck on white Samsung logo or the animated logo?
por
i think this kind of problem of samsung unit isa a big problem for samsung users now...
por
Thank you, my phone is good as new.
por
Need some help i have samsung j100 ml and i flash it with the exact firmware then it says pass but after it it wont turn on anymore, even download mode, as well as charging. How to fix it? Can you help me please?
Please pm me asignar45@gmail.com
por
Mostrar 3 comentarios más
Respuesta Más Útil
Do a factory restore, pull the battery out and put it back in to ensure it is off, Press and hold the Power+Volume up+Home buttons at the same time. Release the Power button when the Phone vibrates. Continue to hold the Volume+Home buttons until the Android logo appears. From the Android system recovery screen, select wipe data/factory reset.
Calificación 9
Comentarios:
@hortman see told you I'd vote for this
por
Hello can someone help me. my samsung galaxy j1 is not working before it is stuck on bot loop i factory reset then after that its always going to download mode then it wont turn on even i charge it i was even trying to go to the recovery mode but its really not working pls... Someone help me btw the battery is really flat its theres no bump
por
i have done factory restore but still its not opening
por
@hortman didn't worked at all man, &&^& this stock rom I downloaded on Sammobile.
por
i've tried this but nothing happens, it just stays black
por
Mostrar 4 comentarios más
I tried but it just wont star at all
Calificación 1
Comentarios:
Am already reset factory.
And on the phone. But not working 4G ?????
por
Its still not working .. Now it just vibrates ..turns itself off again n again please help(princessvkheswa@gmail.com)
por
can someone help me please,after i flash my phone using Odin,it wont start up,i only seen a black screen even if i charged it stil no logo,please help me,its not my phone actually its my friends phone,its Galaxy j1,please pm me (chujaye@gmail.com)please help me.
Calificación 1
Comentarios:
Can someone help me please, after i flash my phone using Odin, it wont start up, i only seen a black screen even if i charged it dont show if its charging or not its just blank and no logo,please help me, its Galaxy J1, please pm me @successemmanuel458@gmail.com thanks friend.
por
experiencing the same problem also.
por
having the same problem as well
por
having the problem too
por
por
Mostrar 2 comentarios más
Can someone help me. After i flash my phone, I flashed wrong firmware. Result it wont start up. even if i charged it don't show if its charging or not its just blank and nothing i understand what hapend. Again I go to take flash it's won't take flash. please help me, its Galaxy J100H, please pm me nur.sujon@outlook.com thanks friend
Calificación 0
Añadir tu respuesta
Miranda Creegan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 39
Últimos 7 Días: 338
Últimos 30 Días: 1,633
Todo El Tiempo: 30,853
