Saltar al contenido principal
El portátil Toshiba Chromebook 2 se lanzó en 2014 y el número de modelo es CB35-B3340. Este Toshiba Chromebook es plateado con una pantalla de alta resolución de 13.3".
Preguntas 24 Ver todo
Are replacement keyboard/top cases compatible across different models?
I have a Toshiba Chromebook 2 2015 with a Canadian English keyboard, and would like to replace it with a USA keyboard (the enter key bothers me as I am used to the enter key of the USA version.)
My question is- do I have to buy a keyboard/topcase specific to the Toshiba Chromebook 2 2015, or can I use one from the previous Toshiba Chromebook 2 model?
All the Toshiba Chromebook 2 models look physically identical, so I imagine this would work. I understand I would be losing the backlit keyboard feature if I did so, as I would just like the cheapest replacement possible.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi!
You can try???, just keep in mind not to damage the new keynoard if you need return it. Just make sure that the connections, size and shape are the same before you buy it...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
madmaxmedia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 109
