Saltar al contenido principal
Modelo A1419 / EMC 2806 / Finales de 2014 o mediados de 2015. 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 finales de 2015 / 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (iMac17,1) Todo con pantallas Retina 5K
Preguntas 521 Ver todo
Upgrading Processor on Late 2015 iMac 27
Late 2015 iMac 27 Retina 5k
I have two iMac 27's. One has an an Intel Core i7 processor.
The other one has an Intel Core i5 processor.
The speed difference is noticeable, so I'd like to upgrade the i5 to an i7 processor. Can someone please give me the i7 processor model number?
Can it be swapped plug & play, with no other concerns?
Es esta una buena pregunta?
Puntuación 5
4 comentarios
Thanks. I already scanned that process. It's the easy part.
That didn't address my original question.
- de
Processor Name: Intel Core i7 6700K
Processor Speed: 4 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
This is the processor that i have already use.
- de
I'm having an issue with the i5 logic board as well. My question is the video card a part of the logic board?
- de
Hi yes it is a part of the Logic Board.
- de
Agregar un comentario
5 Respuestas
Solución Elegida
It’s still working the best. No problems at all. I use it daily.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
thx a bunch! I was weary about the tdp rating being nearly 30 watts higher
- de
Respuesta Más Útil
Hi!
I have just upload a video in Youtube for the imac 27" Late 2015 CPU Update.
I try both i7-7700K and the i7-6700K.
I have desassembly ans asasseble the iMac 7 times! :)
The i7-7700K will NOT WORK!!!
The i7-6700K WORKS Fine!!! Very smooth...
Operation Temps: 40-55 idle, and 85-99 (Rendering).
Very happy for updating the CPU ( I had the i5-5600 3.2Ghz)
Puntuación 15
18 comentarios:
Thank you for your info. You saved me a lot of time.
- de
You are welcome!
- de
Hey i have the same problem i also buy i7 7700k and it doesn't work with my late 2015 27 iMac. and i also deassembly and assemble it 8 times as well :D
So now i need to buy 6700 or 6700 k ?
- de
I used the i7-6700K, and it works fine! the i7-7700k will NOT work....
- de
I also have the same imac, and I plan to migrate from core i5 to i7. Thanks for the help!
- de
Mostrar 13 comentarios más
Here's the guide for doing it: iMac Intel 27" Retina 5K Display CPU Replacement
UPDATE
The iMac "Core i7" 4.0 27-Inch Aluminum (Retina 5K, Late 2015/Skylake) features a 14-nm "Skylake" Quad Core 4.0 GHz Intel "Core i7" processor (6700K) with four independent processor "cores" on a single chip, an 8 MB shared level 3 cache, 8 GB of 1867 MHz LPDDR3 SDRAM (PC3-14900) installed in pairs (two 4 GB modules)
4.0 GHz Core i7 (I7-6700K)
http://www.anandtech.com/show/9483/intel...
Puntuación 6
7 comentarios:
I am wondering if someone has tried upgrading this model to 7700k (kaby lake). Since the socket connection is the same. I don't see a reason why it wouldn't work (apart from EFI or some other safety checks).
- de
Its more than the socket its also the PCH needs to support it and the systems firmware as you noted needs to handle it.
I'm not sure if given the amount of work and the risks in replacing the chip are worth it given the slight speed bump you would get.
- de
Would this clear this question?
SnazzyLab dit it in this video.
https://www.youtube.com/watch?v=knMM9dRw...
- de
taogde Nice video! I invited him to join us.
- de
SnazzyLab did upgrade iMac 2017 not 2015 !
- de
Mostrar 2 comentarios más
Hey guys, do I need to install new OS after change CPU? For windows OS, I know we have to but not sure for
Puntuación 0
3 comentarios:
Not for macOS
- de
No as Dan said.
But in my opinion if you have other problems on the macOS is good after some years to make a new "clean" installtion. :)
- de
When do you have to reinstall for Windows?
- de
Guys, have you ever tried to put the CPU from the 2017 in the 2015? It is the same socket! Could probably have the support because the 2017 iMac already use it! Any comments?
Puntuación 0
2 comentarios:
Emanuel, George Siorios tried putting an i7 7700K and it does not work. It will work only with 6th gen CPUs. The i7 6700K being the best you can put on it, for the Late 2015 models.
- de
Hi to all.
yes, the socket maybe is the same but the CPU is NOT working..
- de
Añadir tu respuesta
clearw estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 94
Ultimos 30 días: 429
Todo El Tiempo: 38,416
